Will a MZ201 work in a pusher aircraft? Is Compact Radial Engines still around?
Hello everybody,
I was wondering if anyone has succeeded on using the MZ201 in a pusher application? I have a MZ201 and was thinking of using it in my Kolb Ultrastar...
Also, I was unable to find the website for Compact Radial Engines, are they still around?
Thanks in advance,
Jeff in Colorado
http://www.compactradialengines.com/
Check with Leon for info. I am assuming the 201/202 engines are built like the paramotor engines.
Found lots of infor via Google on the CRE MZ engines.
Jim
Reason: added information
Jim, good suggestion and thanks for the link. I have emailed Leon to find out...
Jeff in Colorado
