Originally Posted by
Matt Gonitzke
I would recommend learning how to do stress analysis by hand. Finite element modeling is very much "garbage in, garbage out". If you put in bad inputs, you'll bet bad results, and if you don't have years of professional training and experience, you'll have a difficult time determining if the results are believable or not. You would need to validate the results with some hand calculations anyway, so you might as well just do it all with hand calculations. In industry, dedicated finite element analysis software is typically used for these type of things, as it allows much more control over the mesh, loads, constraints, and so on.
