Hi Byron,
1. I saw those but I have an Odyssey battery charger and not a Battery Tender. So I need some way of making the connection from the alligator clips on the charger to the connector at the opposite end of the ring terminals. So I need something with the mating connector that I can then connect to the alligator clips. I suppose I could buy one of their extension cords - one end will be what I need. I could cut off the end I don't need, strip the wires and attach them to posts which would be external to the airplane and onto which I could clamp the Battery Charger alligators.
2. Would you put a larger fuse in there?
thanks!
