Yes, this is basically trying to answer a question in another forum about how many auto-conversions are installed in homebuilts. It should be easy enough to extract from the FAA registration database. But about 4000 homebuilts have an entry that just says, "Amateur-Built/Experimental Engine."
While the FAA database includes a lot of VW and Subaru engines (and a smaller number of Corvairs), it really lists few of the V6/V8 sorts of conversions that seem to get all the press. As you can see above, the January 2016 FAA database shows *no* aircraft powered by Chevrolet engines (other than Corvairs). Yet they can be found in the NTSB database, so the assumption is many of the liquid-cooled Chevy engines are actually listed with the generic AMA/EXP tag.
But...how many of the 4000 are of each type? Are they all auto conversions? Or are folks registering their Continentals and Lycomings as AMA/EXP for their own reasons (such as their not coming up on an AD search....).
So I took those 4000 and compared them to my NTSB accident database. The NTSB almost always lists the engine. So, for about 550 of those 4000, I found accident reports (I did have to be careful it wasn't another plane with the same N-Number). I worked out how many of the 550 were Lycomings, Continentals, etc. As you'll see above, while the FAA database shows no Chevy-powered homebuilts, there were 21 just in that 550-aircraft sample. So, obviously, the number of auto-engine homebuilts were being under-reported, and my analysis was an attempt to extract the true fleet sized.
Oh, yes, found several of those. Some planes had more than one accident, with a different engine each time.
