Just within the past months or so haven't been able to log into the EAA forums without first logging out of FB.
Keep getting the error - "too many redirects". Cleared ALL the cookies as required for the error. Still a no-go.
After logging out of FB then coming back here it asks to log in via FB?
I close the window then try again, it then brings me to the forums main page where I can log in normally with my EAA credentials.
Another thing noticed. I "can" get to the forums main page and any sub forums while logged into FB. It's when I click on a topic that the errors occur.
No sense going to a forum if one can't read anything.
Looked all over the settings and maybe I'm missing something - Is there a way to turn off FB integration here?
TIA for any help.
EDIT - Finally found the setting (I hope) - Settings | My Settings | My Account | Edit Connections
Turned that bugger off!
Just FYI - there's still something wrong though if FB connections are used.
EDIT Again - Waited over night for things to propagate. No, still doesn't work.
Found that an easy workaround is to use the "Incognito" mode. (Chrome)
