Originally Posted by
Mark van Wyk
Technically speaking, you may be right. My mechanic is still checking this out. If (as I suspect) there is no problem with my vacuum system, filters are OK, and it is indeed simply a failed instrument, do you think 80 hours/18 months is a reasonable amount of time to expect this instrument to work? Or, would I have just cause to be dissatisfied? Should I just shut up and buy another one? Or, should I complain a little bit? Considering that it failed so soon after the warranty expired and with relatively few hours with absolutely no abuse (such as spins or unusual attitudes) should Gyro House stick to its warranty terms, or should they grant me some leeway, such as offering to rebuild the unit they sold me?
