Has anyone heard when will the 2016 NOTAM be available? I haven't found it in the EAA AirVenture or FAA websites.
That's interesting. Usually it comes out around the end of April. Since it wasn't in the April 28 book, the next opportunity for publication (on the FAA side) is May 26.
The 2016 AirVenture NOTAM is awaiting a few changes by FAA, hopefully to be resolved in the next few days.
While the basic VFR arrival procedure will be much the same as in prior years, there are many changes throughout the document, so you'll certainly want to get and read the 2016 NOTAM when it is available. Among the changes are radio frequencies, the taxiway layout on the north side of Wittman Airport, runway markings, and VFR transponder use.
An EAA webinar on June 8th will highlight all of the NOTAM changes and include tips on flying into AirVenture.
Glad you're making plans for the event -- see you at Oshkosh!
-Fred Stadler
EAA NOTAM volunteer chairman
Thanks for the update Fred. I was beginning to get nervous. By this time every year I usually have a bunch to distribute to our Cessnas 2 Oshkosh pilots in Juneau.
The 2016 AirVenture NOTAM is now online at www.eaa.org/en/airventure/eaa-fly-in-flying-to-oshkosh/eaa-airventure-oshkosh-notam
A link to order the free, printed-booklet version of the NOTAM will be available in the next few days.
How about the FAA change it from turn transponder to Standby at 30nm, to leave transponders On so that we can all see each other on the FAA mandated ADS-B so that the 13000 of us using see and avoid don't bump into each other. Even leaving Transponders On till RIPON would be a significant improvement in SA at that funnel.Ted
Yes, Ted, I was expecting that change this year, too. Not there, huh? I'd like to see the reason for that rule, with some quantitative analysis, not just "too many, it'd saturate their radar." My guess is it's to make IFRs more readily visible on the radar screen, since their transponders have to be left on.
I sent a note to a Big Wig Pal in DC asking him to help me get a substantive answer rather than the "brush off...it will saturate our radar" answer.At the risk of self incrimination, I kept my Xpndr on all the way to RIPON last year and saw that many had likewise "forgotten" to strangle their parrot. I think we ALL should keep our Parrots squawking all the way RIPON and see if Uncle suffers any ill effects. If so they can update their ATIS with an emphatic "Turn your transponders Off cuz it is causing problems!"Ted
With that many airplanes in that small of a chuck of sky, I wonder if ADS-B traffic would really add to the level of safety. Given that it would cause a lot more head-down time, I think it might actually make things worse.
Jeff Point
RV-6 and RLU-1 built & flying
Milwaukee, WI
"It All Started Here!"
