Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: What would you choose?
    If you had to fly with only one instrument, what would you choose?
    Byron J. Covey
    Guest
    Quote Originally Posted by Glory Aulik View Post
    Fuel gauge.
    BJC
    Harmonica.
    To be serious, I'd say oil pressure. My Fly Baby provides audible airspeed and tachometer, looking at the ground gives me altitude and (with a map) heading, clock gives me a good indication of fuel remaining.
    CLOCK!
    Even when nothing works, rentals still charge by the hour!
    George Sychrovsky's Avatar
    Shirley MA
    I actually did fly with only one instrument for years
    Disclaimer ; opinions of others will vary depending on what they’re selling.
    http://the-grand-design.com/
    Mayhemxpc's Avatar
    Manassas, Virginia
    Glory,
    Since you posted this on the IMC thread, I take it that you did not mean engine instrument. In VFR, I agree, the oil pressure gauge (the one we normally don't look at more than a minute after starting the engine) is the most critical.
    I am also assuming that my wristwatch doesn't count as an instrument.
    Byron, she's asked about the MOST important gauge, not the least important one.
    Chris Mayer
    N424AF
    www.o2cricket.com
    Byron J. Covey
    Guest
    Correct ... we disagree, assuming that the airplane is not a glider.
    BJC
    I've had static failure. Having the GPS-moving map covers for a lot if you can call that an "instrument."
    NW FL
    If I were down to only one instrument, I would conclude that this is a good day to stay home and re-arrange my sock drawer.
