Results 1 to 10 of 13
Thread: Name this plane! First time ultralight enthusiast
Threaded View
  1. #13
    Apr 2016
    Having gone to school for aircraft maintenance I have a fair appreciation of how little can go wrong with a routinely inspected and maintained aircraft. Of course this isn't no Cessna. The entire tail on this thing looks like one strong crosswind would leave you spiraling back to earth. Which is the only reason I like the BRS idea for the rare occasional of an airframe failure. Engine failure which I can see being a common issue with one of these engines doesn't worry me too much until I realize most of my properties are in the boonies and you get a choice of birch maple or fir or the occasional mountain top or stream. So for my conscious I will likely keep the BRS. Speaking of engine, I started work to get it running and oh boy... Fuel systems being my specialty, cleaned the carb, I started with that and installed all new poly(tygon) lines the old ones had literally vanished from deterioration. And the damn mud wasps wreaked havoc on this plane! Removing sand from the vacuum port without getting any in the engine is no easy feat. So my fuel system is complete. Then completed the pull start which seems to have a lot of resistance which I'm sure is from all the pulleys that send it into the cabin. Moment of truth, no spark.. Bummer so now I'm working on pulling the stator and all that fun stuff!
    Question for you guys! There is a medium sized metal box with a fuse and 2 connectors that hang out the top and it is wires into the stator connectors with roughly 20-22 guage wires. This box isn't connected to anything and I don't see any connectors that connect to it laying around anywhere. Anyone know what this thing is?
