Results 1 to 4 of 4
Thread: wanted to find
    Mar 2016
    wanted to find
    a calvin parker tinnie 2 aircraft in wisconsin. please call neal 9068642852.
    Nov 2012
    There was one just a couple hundred miles from you. But the man has now moved to New York. I know he still wants to sell her, but now its a distance away.
    That is if we are talking about the same airplane.
    Name:  saved pics 2 276.jpg
    crusty old aviator's Avatar
    Jun 2012
    You can't get here from there
    Yep, it's called a Parker Teenie Two (an improved version of the mid-60's Jeanie's Teenie) and has a 4 cylinder VW. Gary Watson simplified it in the mid-70's and put a half VW on it and called it the Windwagon. Morry Hummel made the Windwagon even better and called it the Hummelbird. If you want to fly upside down, Bradley Aerospace in Chico, CA sells a kit for their version of this design, called the Aerobat. If you check the FAA's registration database, you may find some near you, and then you can contact the owners to see if they'd considered selling their old girlfriend to you.
    Quote Originally Posted by nfoote View Post
    Found only one Teenie Two in Wisconsin, N9FT, owned by Paul Laurent in Menasha.
    59 on the US registry, using my search criteria.
