I have a freshly rebuilt/overhauled Destiny ST single-seat powered parachute for sale. I just recently completed a complete overhaul of this machine with 70-80% new parts and fresh powdercoat in Granny Smith Green (same as 2011 Chevy Camaros). This machine flys really well. Destiny is equipped with a Elan Sparrow 370 chute which was made just for this machine. The chute has a fresh inspection and no problems noted. The engine is a Hirth 2702 40hp with a Hirth gearbox and a 3-blade Powerfin prop. Engine has had seals replaced along with new plugs, filter, rubber carb boot, etc. and has less than 25 hours of run time. The instrument panel is equipped with an MGL EMS-1 engine monitor and a standard altimeter. To conserve weight there is no electric start or battery but there is an electrical system to run the MGL and could be used for a small handheld COM and/or GPS. This machine makes legal Part 103 weight as equipped. Machine performs well with pilots up to 235-240# (the heaviest that has flown it so far) and the initial test flights were done on a 95 degree day with a density altitude of about 3500'. Located in North Carolina.
Asking price is $6500. Any reasonable offer will be considered. It will be hard to find a "Like Factory New" single-seat PPC for a comparable price. This thing really does look as if it just came out of the factory.
This would make someone a great Christmas present!
Email with questions.
Tim A.
Size:  61.4 KBName:  IMGP0822.jpg
Size:  103.4 KBName:  2011-08-15_13-34-00_576.jpg
Size:  99.2 KBName:  2011-08-15_13-35-24_334.jpg
