Aw, darn, Janet. Here I was all happy because you were sticking up for me, and then you had to put in that little jab in the parentheses. I see you also are not a coward and use your real name. Hopefully the craven "ssmdive" -- proud owner of1974 7ECA Citabria and 1986 Pitts S1S -- won't do a Google search on you and post your information. I assume ssmdive hides the tail numbers on his airplanes, also. An FAA database search will reveal a lot about him, too.
