Maybe if you looked up A6M instead of AM6 you'd find more. Why don't you design your own scale A6M. Think of all the wonderful things you'd learn. I recommend you build it out of sheet metal though. The spruce longerons with foam and fiberglass was fine for Ken Rand's designs, but even Rutan's designs are experiencing a lot of problems that Van's planes never will.
