Hello all its been a while I flew one test last year I had promised to stay grounded while I built our new home. I had made a change it was all bad. barley got out of the water. The house finished I am undoing the bad . I raised the rear floats 2 inches today that will give me more rotation next I will add back the part I cut away replacing an enhancing. What I believe was making the whole concept work. I had thought the concave keel line to the stern was adding drag . It seems it was actually creating lift helping to get up on plane quickly.
So yes I am still around and all is well with me . Not with my house hold the wife is terminally I'll with cancer.That will determine If I get to fly a new test. I will post new pictures after I add things back on. Staying busy helps with getting through this bad times.
