601 is a stable flyer and capable of good cross country flying, assuming the build was of good quality. I would recommend transition flight instruction from a CFI experienced with the 601.
If you are considering buying the 601, contact the Zenith builder's group and find a couple of Zenith builders to look at the plane and give their opinion. Builders usually have more insight about how well a kit was made than an unfamiliar A&P.
