Alternative smoke oil?
Hi
I have noticed that commercial smoke machines used in the entertainment industry etc. are using a "smoke liquid" based on glycol rather than based on mineral oil. Also in the RC community some seem to use glycol/water mix as alternative to various oil based mixtures. Glycol is probably also safer from a health perspective both for the pilot and the audience, and the flash point is also in the same order of magnitude. So are there any drawbacks, and what about compatibility with aircraft paint and gelcoat?
Any experience out there regarding glycol based smoke liquids for full scale aerobatic planes?
Fly safely
You need to be very careful with atomizing glycol at high temperatures. It can make a lot of nasty formaldehydes. Even those of us using it for stage smoke have to watch it when it would otherwise be considered safe.
Ron what type of oil do they use on a stage?
It's propylene glycol, but you've got to be very careful not to run the heater to high. If it starts to smell funny, you have it too hot and it's generating bad stuff.
I thought about adding a smoke system to my little airplane. Not for aerobatics but for practicing things like steep turns and s-turns over a road and for turns around a point one could keep their eyes outside the cockpit and tell if they are loosing or gaining altitude without ever looking at a gauge in the cockpit.
Tony
Umm...an altimeter would be cheaper and more accurate. You do understand that smoke settles and moves due to the wind? Your manouvers are supposed to be done to adjust for the wind so that your ground track is consistent.
The smoke oil kit people call it a VISUAL COLLISION AVOIDANCE SYSTEM if you want an excuse.
Most casual smoke system users find that the smoke comes in through every crack in the belly to create IFR in the cockpit. The airflow across the top of the airplane creates low pressure that pulls exhaust and smoke in through belly openings as far aft as the tailwheel. You have to seal every possible opening. Most non-airshow folks use the smoke system a couple of times and then it becomes dead weight.
Canopus oil, formerly Corvus oil, comes in 55 gallon drums and costs $400+. At the airshows we get it for free, but most civilians don't want that expense. The good substitutes for Canopus are even more expensive.
Its less cool in practice than it is in theory unless someone is providing it for free and paying you to use it. It does enhance an airshow performance.
You can buy it in gallon jugs for around $25/gal.
To put that in perspective, to get really good smoke you want to flow at least 1, and generally more like 2 gallons per minute.....
Yep, it's not cheap. Even by the barrel you're paying for the fun. Also note that the size of a smoke tank in most small aircraft installation is measured in minutes you can count on with your fingers.
