Has anyone done an AOA installation in fabric wings? Any tips you would like to share?
An AOA installation is no different between fabric, aluminum, composite, wood, etc. Any installation off the surface will be the same. A differential pressure on the surface may be affected due to the fabric vibrating, unsteady flow and the very small differential pressures. If I may ask, what are you thinking?
