Quote Originally Posted by Steve Johnson View Post
I would suggest picking Sportsman Power Proposal C. The other proposed sequences have either two 45 degree lines on the same line, or have a 45 degree up line on a downwind line. Both of these situations will cause Sportsman pilots to work harder to stay in the box or take an out. The C sequence does not have either of the above flaws, and will allow Sportsman pilots to better concentrate on flying good figures without worrying as much about outs. The 2011 Sportsman Known had a 1/2 cuban 8, followed by a pull humpty, and then a reverse 1/2 Cuban 8. This combination of figures was on the downwind line, which required the pilots to decide if they would take an out or a break. At the Sportsman level, pilots should not have this added burden, which does occur in the other proposed Sportsman sequences.
Steve Johnson
IAC 20081
IAC Safety Chair
I would agree with Steve, the downwind 45 adds an unnecessary difficulty at the Sportsman level, proposal C for Sportsman Power looks best
Tony Johnstone IAC 16578
