Originally Posted by
wakataka
That's right, it's the Sprint that has the single surface and the low stall speed, not the Sport like I said in my previous post. A Sprint with a 447 can get in and out of some pretty tight places.
I fly out of Corning and unfortunately Rainbow Aviation no longer has their 2-place Quicksilver available for training. After the FAA killed the 2-place ultralight training exemption, the trainer had to be classified as an ELSA and could only be used for training under a special approval called a Letter of Deviation. Brain Carpenter said it was taking months to get the Letter of Deviation approved every year. It's very difficult now to find anyone providing training in anything that flies like an ultralight. FAA needs to come up some more reasonable way to allow ultralight type ELSA airplanes to be used for training. The current system requires the LODA be renewed each year and I understand it can take up to 6 months to process a renewal. So how can anyone make a living (or even break even) doing training with their aircraft grounded up to half the year? It's unworkable and it's driving people back to the bad old days of ground based instruction and people basically teaching themselves to fly in the air.
If the asphalt you are referring to is a county road, you may be heading for trouble there. You can't operate airplanes or ultralights legally on public roads.
Martin B.
