I am building a Bede BD-4C and I don't think that I will have any trouble demonstrating that I have done more than 51% of the work. Recently, I was told that if I use any parts from a certificated plane, even the seats, then I will not be able to register the plane as experimental amateur built and will not be able to get a repairman's certificate. Is that true?
Thanks,
-- Art Z.
