Well, to stir the pot, I will throw out the suggestion that too much of our training is repetition of "politically correct" formulas and emphasis on approved procedures. What I mean by that statement is that I see too many instructors teach, and pilots with many hours insist that there is only one procedure appropriate for a situation when in fact common sense says that is not true.
In this case what I see is that the pilot had the full length of the runway in front of him and he went around because he had a problem with the turn to final. All he had to do after stabilizing the airplane was get lined up and land. Someone taught that pilot that no matter what, if you have a problem in the pattern, do not land! I see that at at my local 6000' runway airport. A student who could land 3 times in the length of the runway gets some turbulence on final and aborts the landing. I suggest that student is being taught poor judgement.
An extreme case of this was the KLM crash where the airplane had a fire on board but the captain would not land at the nearest airports because they were not listed in the airline's ops spec (approved airports). For that deceased captain the procedure was more important than saving the airplane and his and his passengers lives. What's up with that?!
Food for thought.
