N414K a 1941 Piper J4-A had its first flight Friday Apr 26 at SSQ, Shell lake WI, having last flown in 1975. The rebuild was started by others for the first 20 years, then I bought it over about 12 years ago. It has been upgraded with a "freshly overhauled" C-85 engine (put together but never run over 25 years ago), metal prop, Groves brakes, Ceconite cover & Randolph products, Cessna 150 mufflers, and a new cowl and baffling system. I removed the electrical system and put in a lite weight starter powered from a cockpit panel-mounted Piper APU plug & a ground based starting battery.
The 20 minute test flight was done by Sandi Randall of Romeo Aviation, Cumberland WI. Now she gets to teach this 2000 hr 172 driver a tailwheel rating.
