Wanted: IVOprop medium, two-blades and hub
Hi,
I'm looking for an IVOprop, two, medium blades, ideally 52" but can go up to 60". Must be medium blade and diameter must be within 52-60". Ground adjustable is perfectly fine but would consider inflight electrically adjustable. For mount on a Rotax 582 geared, tractor, or Hirth 3502, geared, tractor.
Thanks,
Bob Wilson
bwilson4web@gmail.com
