Q: Question on your LED Aircraft Strobe Light (Wig-Wag) & Landing Light System: Would a single ON-OFF-ON toggle switch be appropriate, rather than dual switches, to control the constant on vs. wig-wag functions? For example, up for ON, middle for OFF, down for FLASH? Thanks! Matthew
A. YES! That will absolutely work – 12volts to the center pole, and then your strobe (yellow) to the top, red (landing) to the bottom, and ground the black wire and you’re set. You’re describing a ‘SPDT’ (Single POLE, DOUBLE THROW) switch that Radio Shack etc can provide. This is how our ‘company plane’ is wired, and it works great.
