Results 1 to 4 of 4
Thread: Installing BNC Connectors
    I've posted a brief tutorial on how to install BNC connectors on co-axial cable at:
    http://www.bowersflybaby.com/tech/bnc.html
    Corrections and suggestions would be appreciated....
    Auburntsts's Avatar
    Tampa, FL
    Ron,
    That's a good tutorial. However I've found that unless my "B" length was wider than you listed I'd get a ground error (this was with RG400 and a Garmin GTN 650). Anyway, using Bob Nuckoll's (author of the AeroElectric Connection) tutorial as a guide, I went with A= 1/4", B=1/8", and C=1/8" and that fixed my issues. I used that same coax cutter and a razor blade to make to strip the layers as required.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    Ron,
    Thanks, Todd. I did an image search and found a close-up photo that seems to match your dimensions. I'll update the page to mention this ratio as well.
    Also, was the "ground error" you mention a direct short to ground, or some sort of issue regarding proximity instead of direct contact?
    Auburntsts's Avatar
    Tampa, FL
    Ron,
    I'm not real sure, but my guess is a direct short to ground.
    PP ASEL - IA
    EAA Lifetime Member
    WAR DAMN EAGLE!
