Ron,
Your friendly neighborhood radio tech will tell you that your radio has maybe two internal squelch controls in it. In my radio, a King KY-197, the first is set for the signal level, the second for the level of the audio on the signal. You just need the internal squelch adjusted. I will hazard a guess that vibration and age have affected a component or two.
