If you know how to use a 'scope, do you have other electronics skills? They make chips that easily turn a short pulse into whatever length that you want. Look up the "555". A chip and a couple of resistors maybe on a small "perfboard" in a small box should get the job done if you are so inclined. This can be the educational part of homebuilding......
