Results 1 to 8 of 8
Thread: Afford-A-Plane
    Gainesville, Florida, United States
    Afford-A-Plane
    Hey there. I am building an affordaplane and just wondering if anyone has or knows people that are familiar with this plane? I am already a member of the yahoo group devoted to the plane but thought Id ask in here if there was anyone with knowledge of it. Any ultralight flyers in North central Florida area? Looking for more but the local chapter mostly is GA from what I gathered.
    JJ
    There's several threads on this over in this forum: www.homebuiltairplanes.com
    Romont Switzerland
    The affordaplane sure has it's charm , but I would prefer in the same layout a affordacub!Bst RgdsErkki
    For such an inexpensive plane, there doesn't seem to be a large number of flying examples for something available for several years.
    May 2012
    Chicagoland
    It also builds up very heavy. Like 100lbs heavy. :-/ I'm only aware of one example being built to plans, and that plane "required" 50hp to fly well. It seems good ultralights can fly well on 28. I ended up collecting a lot of information on the plane. ... and upsetting most of the community. But that's another, long, story.
    http://theaffordaplaneresource.blogspot.com/
    Eric Page's Avatar
    Toledo, WA
    Interesting comment, Nerobro. I've owned a set of Affordaplane plans for several years but never got started, mostly because my garage is an inferno much of the year. I'll be sure to do some research on this issue if I ever decide to go ahead with the project. Thanks for the tip!
    Eric Page
    Map of Landings
    Angry The Affordaplane is NOT an ultralight.
    I have the same information. The owner/moderator of the Affordaplane Yahoo group (who is the #1 supporter of this design) states flat out that the BEST you can manage is about 350 pounds (100 pounds over FAR 103)
    The Affordaplane is NOT an ultralight despite the lies on their website.
    Gary in BC
    Quote Originally Posted by Nerobro View Post
    Well, that explains why they won't get off the ground.....
