Originally Posted by
WLIU
The last post is great info for one type of airplane. What airplane are you talking about. If the original poster has the same type of airplane, he may now know exactly where to start. If he is building a different airplane, it may sit on the ground in a different attitude.
On the topic of 4 degree approaches - If you are not doing the ILS, you will find that the typical final approach following the pilot handbook numbers is steeper. Typically, flying a 3 degree ILS is a power approach. Power off, different airplanes glide more or less steeply. I say that as a guy who flys airplanes with glide characteristics that resemble a falling manhole cover. My power off approaches are VERY steep. Cessnas are sailplanes in comparison. So factor that into your landing light mounting, or don't. Maybe you will always fly a power approach at night.
