Anyone doing flight instruction with a "Deviation Authority" issued under 91.319 (h)? Would like to hear about your application process.
Thanks
Mark
Thanks
Mark
Mark:
I don't, but my neighbor does in his RV12. Check the VansAirForce forums under the RV12 model and you'll see his posts. So far he's had quite a few students.
You can train in an experimental as long as there is no charge for the airplane.
unless you have the LODA.
Scott Sheets of Hamilton Illinois is instructing in a Sonex using the LODA. Read article here.
http://www.eaa.org/lightplaneworld/a...1109_sonex.asp
His website has more details and contact info.
http://www.aircrafttransitiontraining.com/Welcome.html
