Thread: Flight instruction in an experimental aircraft
    Sep 2012
    Anyone doing flight instruction with a "Deviation Authority" issued under 91.319 (h)? Would like to hear about your application process.
    Thanks
    Mark
    CarlOrton's Avatar
    DFW Area
    Mark:
    I don't, but my neighbor does in his RV12. Check the VansAirForce forums under the RV12 model and you'll see his posts. So far he's had quite a few students.
    Carl Orton
    http://mykitlog.com/corton
    Todd copeland's Avatar
    Pittsburgh, Pa.
    You can train in an experimental as long as there is no charge for the airplane.
    CarlOrton's Avatar
    DFW Area
    unless you have the LODA.
    Carl Orton
    Scott Sheets of Hamilton Illinois is instructing in a Sonex using the LODA. Read article here.
    http://www.eaa.org/lightplaneworld/a...1109_sonex.asp
    His website has more details and contact info.
    http://www.aircrafttransitiontraining.com/Welcome.html
