I can offer the caution that Stewart appears to go on easily, but a friend reports that the shelf life is relatively short and begins the moment it goes into the can. A friend used some that was not that close to what he thought was the published shelf life and he wound up stripping his entire wing and starting over with a more traditional paint system. So get it and use it while its fresh....
I will note that there is no magic to paint. If you are painting aluminum or composites, PPG or Dupont are still both good choices. Fabric is another story.
I will note that the weight of the finish is generally determined by the painter, not the paint. Just don't over do it.
