Originally Posted by
WLIU
The answer is that you put it back. You can buy linseed oil from AC Spruce, pour it in, spin the structure around to slosh, and drain. There are Airworthiness Directives that require that you do this periodically. Not rocket science.
Linseed oil is pretty benign stuff. If you have ever overheated your frying pan you know that vegetable oil chars. But its not corrosive in that state and only adds flavor to the next meal if you choose to leave it there.
For what its worth, you can bead blast the tubing and use an airbrush, or a hand brush, to epoxy prime and declare success. That finish will be lighter than powder coating. For a fuselage where you will be gluing fabric on and not generally subjecting the tubing to heat and abrasion, powder coating is gross overkill but it looks nice. In a volume manufacturing line it costs less. But for the individual builder or restorer it is not needed aft of the firewall.
