Prop for Acrosport 2.
I have a HO 360 B1B Lycoming powered Acrosport 2 that I am building . I would appreciate any help on what prop would be best for this project. paulhutch
Not really enough information. Assuming fixed pitch, do you want wood, metal, or composite? What is your primary purpose? Not really sure of the rated HP of your engine but a typical Acro II with 180 HP will use a 76x60 or 62 Sensenich.
A lot of biplane prop talk at <biplaneforum.com>
Neil, thanks for the response. The prop I was considering was the Sensenich you suggested. Thanks again paulhutch.
