If anyone is building a traditional 6-pack panel I have removed my vac pump with 500 hours on it, associated filter and pressure adjuster, artificial horizon and directional gyro. Name:  Waldo Panel_edited.jpg
Checked the vanes recently and the pump seems to be doing fine. The DG needs to be adjusted a few degrees every 40 minutes or so, sometimes less often.
Make offer, nothing reasonable refused.
Rik
