Plans for the Fourunner are available from the designer, Callbie Wood. I have his metal wing plans for my Tailwind, and they are very good plans. I'm sure the CF-4 would be as good.
This is Callbie's contact info...
Fourunner Plans
- Fourunner EW is 1250 lbs Empty weight
- Gross Wt 2200 lbs.
- Engine Lycoming 360 with Hartzell CS prop
- Span is 28 ft,chord 5 ft. Airfoil same as W10 TW,
- wing is aluminum.
- Gear legs from Cessna 170
- Full throttle speed @ 1000 ft 195 mph, cruise at 7500 ft about 165-170 mph
- 600-6 main wheels.
Plans $200
Send order and payment to:
Callbie Wood
10717 Old Bailey Hwy
Wilson, NC 27896
919-243-6708
jncwood@bbnp.com
