I believe the differences are few between these aircraft. Which is more desirable to own.....and why? Thanks!
Obviously either plane will do acro very well, but it is only legal to do airshow acro, i e Julie Clark in the A model. I think this is because when the military was testing these planes years ago, they found that only the A model would meet FAA spin recovery standards in all situations. The B does it ok, until you get the cg loading rear of center even if still within limits. So I think the restriction from way back in those days still legally applies to the B.
I think, not sure, that the B actually has a slightly different wing, maybe less dihedreal or washout than the A which accounts for the spin recovery difference.
Some years back a group of B owners got a program to try to overcome this restriction on B acro. They went through a whole test program for spins and recoveries. All went well when they started at the forward cg limit, and as they moved aft. However, just as in the old days, as they got near the aft cg limit the problem began just as it was years before, so they only confirmed this fact.
So just on this fact the A may be more desirable. The A has adjustable seats, that I prefer and fixed rudder pedals. B has fixed seats and adjustable pedals. B has a pressure blow off emergency canopy, which in unlikely to be needed, but may be sightly better. A has a normal cable release for the canopy. It seem the B has a little more room in the panel, can't recall why.
They are almost the same plane. Both are amazingly easy to fly, look good, do nice acro, and can serve ok for cross country. If I had to choose one plane for a forced or emergency landing it would be T-34. With the stall about 48 knots they can be landed slow and on a short runway. They are not fire breathing on performance, being heavy, and with no supercharger. The A, I owned for 10 years cruised at about 140 knots burning 13 gph, holds 50 gallons. It is common to put in larger engines than the 225 hp, either 285 or 300. The 225 hp will climb about 1000 feet at sea level, but requires patience to get much above 12,000 '.It will cruise with a T-6 as long as you are down low, but there is not substitute for a supercharger up high.
If anyone is looking to buy one or get some tips, I can help. Also there is a very active T-34 association and good formation clinics.
I couldn't resist a T-34B story. In 1969 I was stationed at Subic Bay in the Philippines. I belonged to the flying club at Cubi Point. They had two T34B models that had been surveyed out of the Navy and I used to rent one, as a 20 year old for the huge sum of $9.00 and hour - wet. Gas was 16 Cents a gallon so at 14 gallons an hour that was $2.25 an hour for fuel. Even on my E-4 pay of $234.00 a month it was still a pretty good deal.
Go Navy.....but I think I want to do some acro! Hard to imagine you can't in the B.
I haven't been around aviation long enough. Reading the title of the thread I immediately thought "why are they discussing WWII tanks?"
I'd go with the IL-2 Sturmovik.
I wrote a 2 part article regarding the T-34 that appeared in EAA Warbird Briefing.
Part 1: http://www.eaa.org/warbirdsbriefing/...s/1110_t34.asp
Part 2: http://www.eaa.org/warbirdsbriefing/...s/1111_t34.asp
If you have any specific questions I would be happy to answer them.
The T-34 Association is located here: www.t-34.com
Best of luck!
