Need advice for buying router to build wood airplane....
Looking for a router to cut my 3/32 plywood ribs off a template. Router also needs to be able to cut the 3/4 inch template for the ribs and cut out the spar made of 3/4 inch spruce. Also needs to do intricate work such as making 1/4" by 1/4" grooves. Will a small laminate trimmer handheld router work for this?...and do I really need a router table for this kind of work?
