"My Itinerary" website function
Has anyone else had problems with the "My Itinerary" function on the website? After logging in, if I start going through the schedule, and adding a bunch of forums and other events to my itinerary, when I go back later, I see that only maybe 50-60% of the ones I added actually made it to my itinerary.
To make sure I wasn't going crazy, I even tried doing this - if someone else has time, maybe they can try to do the same and see what happens:
- Log into to the airventure site, go to the "Schedule" page.
- Search for an event that is given multiple times, say "Sheet Metal 101" for example.
- Click on "Add to My Itinerary" on some or all of the events that pop up. Be sure to wait for the spinny circle to change to "Event has been added to your itinerary".
- Check on "My Itinerary" and see that not all of the events have been added.
- Search again for the same event (i.e. "Sheet Metal 101") and observe that some, but not all, of the events you previously added still say "Add to My Itinerary" (as opposed to "Remove from my itinerary" which is what they should show if they were correctly added).
I've tried both with the browser on my Android tablet and also using Chrome on my Win 7 desktop PC, and it behaves the same on both platforms; the event is sometimes, but not always, added correctly.
Anyone else seeing this behavior? Maybe I should do what I have done in the past, which is just cut & paste forums I'd like to see into a google doc, but I was thinking this "My Itinerary" feature could be easier to use.
Thanks,
Steve
