2 Seat Tandem Homebuilt Aircraft Suggestions
Hello All:
I am considering building a homebuilt aircraft but I am having difficulty finding the right design. Ideally, I would like the aircraft to have the following:
- Low wing (folding if possible)
- Tandem seating (must have)
- All metal or composite construction
- Retractable landing gear (conventional or tricycle)
- Aerobatic
- Kit available (quick build or non-quick build)
From an visual perspective the MJ-5 Sirocco has a good look but the wood construction is not something that I am prepared to try. A design with similar looks and performance but built using metal or composites would be much better.
I have been looking through all available resources but I just can't seem to find what I am looking for. With the vast pool of EAA member knowledge I am hoping that someone can offer suggestions as to where I can find such an aircraft.
Thank you for your help!
Chris
