You might be able to fly off most of the 40 hours as a solo student. You would need to get soloed and endorsed by an instructor in a similar aircraft, I think. If the aircraft is a single seat you can take the check ride with the DPE on the ground, I think.
Request that Operating Limitations NOT limit student solo when you get the Airworthiness certificate.
