fuel level sender for super cub replica wing tank
I am building a super cub replica and using Piper wing tanks. These are flat tanks with an electric fuel level sending device opening on the upper 1/2 of the inboard end. The tank does not have an opening (other than the filler neck) on the top side.
Piper used a fuel level device (#751767) in this style of tank in PA-18 and PA-22 (tri pacer) to name a few applications.
I am looking for ideas that are more economical and more reliable from the automotive arena.
The closest thing I see in catalogs but have not handled is a Stewart Warner 385 B or C.
I am assuming that I am not the first to pose this question and appreciate suggestions and ideas.
Tim McDermott
ednatim@sdplains.com
Thank you.
These guys may have someting
http://www.speedwaymotors.com/
A lot of the street rods have custom tanks.
Get rid of the electric stuff and weld on bungs for sight gauges. I have never seen a Cub with electric fuel gauges. Not that it cannot be done but the sight gauges have worked for decades.
Fuel Gauge
[QUOTE=Bugs66;23519]Get rid of the electric stuff and weld on bungs for sight gauges. I have never seen a Cub with electric fuel gauges. Not that it cannot be done but the sight gauges have worked for decades.[/QUOTE
Why not put in a gauge like the older Cessna 120's, 140's, 170's and early 180's had? They are simple and non-electric. That's what I would be inclined to do if I didn't want to weld bungs for sight gauges.
