EAA Flight Test Manual
" EAA expects a final version of this AC to be released in the coming months, and is currently working on improvements to the EAA Flight Test Manual and creating associated guidance to make task-based flight testing even easier as the program is rolled-out" from the recent press release.
Q: Will EAA have an easy revision (pdf) to the flight test manual that current manual owners can update?
