I am planning on flying in on Wednesday and parking until most likely Sunday. I will be camping indoors at the YMCA.
This means I believe that I will be showing the GAP sign when I land.
Potential silly question: Do the volunteers lead you all the way to a parking spot regardless of how far away that is? Do you go straight in, or do you typically end up shutting down and tow bar back into a spot.
Thanks.
