Prop Design Software
any recommendations for software to design a new prop? Looking for one that I can fill in the design performance fields (diameter, speeds, HP, ect) and get a good start design to produce a wood prop. Then modify depending on flight test data. Hoping for the software to supply info needed to import into autocad or solid works and have a CNC shop carve it without much converting.
