Thread: Eastwood TIG question
    Good afternoon,
    Are the Eastwood TIG welders compatible with either Miller or Lincoln torches, or do they have proprietary connections?
    Thanks in advance for your help.
    All my best,
    Rob
    Brrrmidji , Minne-SNOW-ta
    are you asking about the welder or the torch ?
    and are you asking if Hobart makes eastwood ?
    can you weld ?
    Auburntsts's Avatar
    Tampa, FL
    Maybe. I believe they all use a gas-thru DINSE connector so now it depends on which size: 25 or 35. The easiest thing to do is contact a company like CK-Worldwide that provides torches and parts across brands to help guide you.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
