Glad to know that there is no minimum age required to fly solo.
Yes there is...you must be 16 to fly a powered airplane solo.
This is good advice but it is not intended to just go out and fly an ultralight without training. You can get dual in a part 23 or light sport aircraft then under the supervision of an instructor experianced in ultralights solo the ultralight. This can be done at any age. Ten and twelve year olds have flown ultralights solo safely. It is never to early to start learning. Do not overlook paragliders and WSC operations in addition to fixed wing or rotorcraft.
Yep, get instruction. If you want to be legally flying solo at 13, flying something under Part 103 is probably your best choice.
As for "solo", one can fly left seat on the Space Shuttle and they still won't view themselves as "a pilot". But they'll become an aviator in their soul when they take whatever the craft is around the pattern alone for the first time. Solo is THE "rite of passage" in aviation. I was lucky enough to do it at 16. I would have felt the same "rite of passage" if I had done it at 96.
At my flight school,i can solo at 14, and im 13
