Thread: Taxiing with Clecos
    Aug 2015
    Taxiing with Clecos
    Is it ok to put a bit of stress on something assembled with clecos? I was asked if it was ok to taxi an aircraft with the rear fuselage still mostly clecos and I don't have a clue if this can damage anything.
    Mar 2020
    Oklahoma City, OK
    Quote Originally Posted by ahramin View Post
    Why would you need to?
    I would say it's a bad idea. Clecos don't hold nearly as securely as rivets. They're fine when used as intended, but vibration and bouncing around would wiggle them around and possibly elongate the holes.
    melann's Avatar
    Jul 2019
    N. Texas, Dallas Area
    Absolutely NOT!!!!!
    Aug 2015
    Thank you both.
