Page 37 of 39 FirstFirst ... 273536373839 LastLast
Results 361 to 370 of 386
Thread: Oshkosh 2021?
  1. #361
    Geedee's Avatar
    Aug 2020
    3 miles from Stonehenge in the UK
    Cheers for the info Dale...much appreciated !
    Cheers
    Gary
  2. #362
    mazdaP5's Avatar
    Just outside of Grosse Ile NAS
    Runway 18/36 operations: 126.6
    Runway 9/27 operations 118.5
    Airboss: 133.85
  3. #363
    Geedee's Avatar
    Aug 2020
    Roger that...noted ! :-)
    Quote Originally Posted by mazdaP5 View Post
    Airboss: 133.85
    Cheers
    Gary
  4. #364
    Note above are the arrival (tower) frequencies. The departure controllers sit on little platforms at the end of the runway called moocows and use the frequencies below:
    Departures on 9/27; 128.75
    Departures on 18/36 118.9
    Departure ATIS: 121.75
    Seaplane base 123.3
    Arrival ATIS 125.9
    FISK "Tracon" 120.7 (if you have transport, sitting out at FISK where they sort out the incoming arrivals is kind of neat).
  5. #365
    PaulDow's Avatar
    Connecticut
    This page is a few years old, but the frequency assignments don’t change much.
    http://www.rstengineering.com/rst/oshkosh/oshfreq15.pdf
    Just be sure if you have a transmitter that you don’t accidentally press the transmit button. The occurrences of accidental, or even malicious, transmissions seems to be becoming more frequent.
  6. #366
    Geedee's Avatar
    Aug 2020
    Great info guys, thanks very much for the details. And rest assured, it's a receiver only ! :-)
    Cheers
    Gary
  7. #367
    Oshkosh, WI
    As Paul notes, frequency assignments don't change often, but they do change. The listed source from 2015 has former frequencies for Oshkosh Ground Control (now 132.3) and the Fond du Lac ATIS (now 121.1).
  8. #368
    flyjbh's Avatar
    Apr 2017
    ORD
    I just got back from SNF and it was awesome! When I was walking into the grounds I could hear the roar of aeroshell taking off and a blue angel arrived at the same time.... I shed a tear I was so happy. Most of the rules were adhered to and there was so much space, you could avoid the offenders. I am pumped for Airventure!
  9. #369
    Geedee's Avatar
    Aug 2020
    Hiya all. Another question...Does anybody know / have a heads-up if the EAA Airventure Oshkosh app is going to be released for this years event ?
    Cheers
    Gary
  10. #370
    EAA Staff / Moderator
    Jun 2017
    Hi Gary -- yes, we will be releasing an AirVenture app this year. Look for it in June!
    Quote Originally Posted by Geedee View Post
