Make a full set of working copies and use them in the shop. Keep the originals protected somewhere and only pull them out to make a fresh working copy. Fair use and copy write come into play when you are incorporating the work into something new, or you are going to distribute copies of an original item. It would also come into play, if you were using the drawings to produce parts based on them, and selling the parts.
